12-14-2024 06:16 PM in
Galaxy S- Mark as New
12-14-2024 06:44 PM in
12-14-2024 06:53 PM in
Galaxy SGeneral Tips
1. _Adjust screen brightness_: Lowering the screen brightness can significantly reduce battery consumption. Go to Settings > Display > Brightness.
2. _Use Adaptive Brightness_: Enable Adaptive Brightness to allow the device to adjust the screen brightness based on the ambient light. Go to Settings > Display > Brightness > Adaptive brightness.
3. _Turn off Always-On Display_: Disable the Always-On Display feature to prevent the screen from consuming battery power when not in use. Go to Settings > Display > Always-On Display.
4. _Limit background apps_: Restrict background apps to prevent them from consuming battery power unnecessarily. Go to Settings > Apps > Background apps.
5. _Turn off Location services_: Disable Location services when not in use to prevent battery drain. Go to Settings > Connections > Location.
Advanced Tips
1. _Use Power saving mode_: Enable Power saving mode to limit CPU performance, reduce screen brightness, and turn off unnecessary features. Go to Settings > Battery > Power saving mode.
2. _Use Ultra Power saving mode_: Enable Ultra Power saving mode to restrict app usage, reduce screen brightness, and turn off unnecessary features. Go to Settings > Battery > Ultra Power saving mode.
3. _Limit network usage_: Restrict network usage for apps that don't require internet access. Go to Settings > Connections > Data usage > App data usage.
4. _Turn off Bluetooth and Wi-Fi when not in use_: Disable Bluetooth and Wi-Fi when not in use to prevent battery drain. Go to Settings > Connections > Bluetooth and Wi-Fi.
5. _Update your device's software_: Ensure your device is running the latest software, as updates often include battery life improvements.
Additional Tips
1. _Monitor battery usage_: Use the built-in Battery usage feature to monitor which apps are consuming the most battery power. Go to Settings > Battery > Battery usage.
2. _Adjust app settings_: Adjust app settings to limit their battery usage. For example, you can limit the frequency of email checks or social media updates.
3. _Use a battery saver app_: Consider using a third-party battery saver app to help extend your battery life.
By implementing these battery-saving ideas, you should be able to extend your Samsung Galaxy S24 Ultra's battery life and reduce battery drain issues.
If this reply answered your query please mark my reply as "resolved" by clicking 3 vertical dots on top right of my reply. Thank you 😊
12-14-2024 07:35 PM in
12-15-2024 11:54 AM in
12-14-2024 11:38 PM in
12-16-2024 06:39 PM in
Galaxy SDear Samsung Member,
We regret to hear about your experience with our product.
To fix battery drain issue please use the link to perform some easy troubleshooting steps: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps:
3. If you do not remember then reset (Forgot password) your Google account.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
