Battery issues after one ui 8
(Topic created on: yesterday)
S24ultra11
For all the people who are facing battery drain issues after one ui 8 update, First clear cache of the phone and check if it's not helping then under device care change performance profile to light and if you are using ram plus diable it. Your battery life will go up by atleast 50%.
In my s24 ultra i got 6.5 hrs of SOT and still 48 percent battery is left.
Only gaming performance will come down if you use light performance profile and no other app or anything else is changed.
Please try and comment if you get better battery life.
4 Comments
YOUR_EX
Expert Level 3
Dear, battery drain issue after software update is comman issue, wait for days it will be soleve. if it not solve, kindly please complaint to the samsung customer support team or samsung service center through the WhatsApp or call, Nd I hope they solve your issue and make u face smile.
If u find this is helpful Click on the three dots of my replies right corner nd accept the solution😊
S24ultra11
Waste reply same copy paste and begging to accept as solution fed up of people like you. Customer care is chutiyaaa ppl they don't care or solve anything
SherryGujral
which app's cache need to be cleared ?
S24ultra11
Phone cache not any app
