06-11-2025 03:17 PM in
Galaxy S- Mark as New
06-11-2025 03:30 PM in
06-11-2025 03:34 PM in
06-11-2025 03:40 PM in
06-11-2025 03:41 PM (Last edited 06-11-2025 03:42 PM ) in
Galaxy Shttps://youtu.be/ciotFoMOEl0?si=QlHJzL-49oeWud4q
06-11-2025 03:46 PM in
Galaxy SCustomer service pe ja ke aya to bola ki battery ka koi issues nehi .chahe to ekbar format and software update de ke dekh sakte he. Data backup kar ne k liye bola he . After updating aa sab issues thik ho ga bhai ?? Tension me hu bohut .or kon sa karna thik ho ga hard reset yea software update firse bcz maine already colours os 7 update kar liya jis din phone delivered hua tha us din hi. Plz guid me .
06-11-2025 03:50 PM (Last edited 06-11-2025 03:51 PM ) in
06-11-2025 03:31 PM in
06-11-2025 04:57 PM in
Galaxy SAdd apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
