Resolved! Solved
Battery draining too fast after One UI 7 update
(Topic created on: 04-29-2025 09:33 AM)
Ishitwa7
Beginner Level 3
Hi Samsung and Samsung Community,
This is a growing new issue as many of us are facing the same thing. After the One UI 7 update, I have noticed that the battery is draining very fast. I am on a S24+. I checked with many friends and Samsung users, and all are facing the same battery issue after the update. Please do something to sort this.
goodthings
6 Comments
goodthings
It's a major update reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
Ishitwa7
Beginner Level 3
Tried that too. But the issue persists. It needs another security patch update i feel.
goodthings
goodthings
Your's most welcome to here.
kpmistry1977
Yes...same here on S23ultra...it's 10% battery draining fast as average
firozali10
Hello guys, I have samsung m35 5g. But since I purchased it's taking too much time to charge 100% and not only this , battery draing too fast. I don't know what setting I have to do for fast charging. Even I also used different charger fast and medium doc. But it's taking same time to charge battery
