Battery draining issues
(Topic created on: 05-08-2025 07:36 AM)
Narendrapadavala
Beginner Level 5
My S23 ultra have an battery draining issue after updating my phone to One Ui 7. Iam observing from one week and I usually charge my mobile one time per day but after the update iam charging it twice per day and iam thinking there are bugs in the update please fix those bugs ASAP.
I have checked everything like background applications and other AI features everything is fine and cleared cache memory.
3 Comments
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution . Thanks.
goodthings
Your's most welcome to here.
cs_member8
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
