Battery draining issue
(Topic created on: 03-28-2025 12:57 PM)
Kumarsir
Huge battery draining issue noted in s22 ultra after February update and problem not resolved after March update
11 Comments
Wodehouse
Simple steps to save battery at the cost of sacrificing luxury
1 Enable Power saver
2 Enable performance mode light
3 Enable adaptive power saving instead of basic
4 Enable adaptive brightness
5 Disable AOD
6 Enable extra dim
7 Change display to natural
8 Screen time out to 30 secs (system default)
9 Record videos in FHD
10 Restrict gaming to HD or FHD and slower frame rate
11 Switch to dark mode
12 Disable near by device scanning
13 Disable WiFi scanning
14 If 5G is unavailable change network to LTE/3G/2G
15 Allow the battery to drain completely and recharge,say once a month.
16 Enable auto restart
17 Run device care
18 Disable apps running in background.
19 Disable RAMplus if you dont use memory intensive apps and do heavy multi tasking. Available RAM usually around 2 to 3 Gb is more than sufficient for normal tasks.
20 Uninstall bloat ware that came with your phone,eg. Spotify,LinkedIn etc.
You can mix match the steps above and arrive at a usage based on your needs.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
Kumarsir
I appreciate your suggestion. According to your guideline battery will last long but why i compromise to console himself that there is no battery draining problem. This is the technique to hide the original problem. I want to use my mobile in the previous way and there will be no battery draining issue.
Thank you sir
goodthings
Kumarsir
Thank you sir 🌷
goodthings
Your's most welcome.
goodthings
Your's most welcome to here.
cs_member9
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
Kumarsir
Thank you sir 🌷
Kumarsir
Your suggestions are fine but all these are only to suppress and hide the original problem.
Thank you sir
