Battery draining issue on s22 plus
(Topic created on: 07-05-2025 12:15 AM)
deepaknwn
After updating it to one ui 7 the battery backup is not good as it was before, currently it is giving 4 hours only.
4 Comments
Mr-RKS
Indeed, One UI 7 may not be fully optimized at this time.
BiRdMaN
Send an error report along with log files to customer support through this members app and Samsung will fix it in the next update. To do that follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful please Accept it as a solution Thank you 😊
goodthings
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue and wait for next update maybe fix it by Samsung team soon. If you like please accept as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
