Battery drain
(Topic created on: 03-18-2024 11:57 AM)
kamesh01
Samsung s23 mobile battery drains very fast from 10% to 0% in 2 minutes. ..is anyone facing the same issue ?
3 Comments
Pradum_yadav
Haa bhai
Sayan_SS_
Please Charge Your Device Between 20% to 85% and Limit The Background Uses of Other Apps.
Still The Battery Issues 🔋Remainded Please Complain To Samsung Support.
To Complain To Samsung Support Follow The Steps:-
Open Samsung Member→Click on Support Present Below→Click on Report→Type Your Report And Clip The Image Through The Clip Button Present Above→Click on Send.
goodthings
