Battery drain
(Topic created on: 02-25-2023 11:36 PM)
bikano
Is it ok or i am the only one seeing a significant drop in battery after one ui 5.1
16 Comments
Not applicable
Try disabling "Adaptive Battery" from Device Care > Battery > More Battery Settings > Toggle off adaptive battery and Reboot
bikano
Which device do u have,and can u share your sot
Not applicable
Galaxy A13
It's actually Learning usage pattern because I recently did a factory reset on my phone.
But I get average 6-7 hours Screen on time after consuming OTT services, whasapp, youtube etc. I usually charge my phone upto 85% once in a day.Screenshot_20230225_234638_Device care.jpg
bikano
Mine too coz i recently reseted my phone but i think i am getting less sot than before due to one ui 5.1
markwilliam
Dont disable adaptive battery...you are only making your battery life worse by disabling it...adaptive battery needs to be turned on to extend the battery life
Not applicable
You can check on other forums or just google it by typing "Should I disable adaptive battery ?" You'll find a majority of Reddit posts and also YouTube videos that saying to disable adaptive battery to improve performance and also battery life.
I also disabled adaptive battery and I've extra 2-3 hours SOT improvement and also animations are quite smooth without it. So I definitely say give it a try, if it makes things worse just toggle it On.
markwilliam
Extra 3 hrs sot?? Are you serious?😮
Not applicable
Give it a shot, your phone will feel less jittery also. Everything will be more responsive.
markwilliam
Ok i am already on it...will let you know if there is any difference
