Battery drain problem
(Topic created on: 05-03-2025 06:04 PM)
nitaig
I am a Samsung s23 user. Ever since I updated to ui 7 my battery is draining very fast.
6 Comments
A_Arif
Same...I am also facing the same issue in my S23. @samsung kindly fix this problem soon
KMVVK
I have been facing beetery drain issue on my Z Fold 6 after updating to One UI 7...plz guide how to fix...
Su_Jaan
Same bhai
Subirhelps
Try wipe cache partition and reboot device
Enjoy!
If you liked My Suggestion then click on three dots (⋮) on my comment and select "Accept Solution"
RACE_IST
This is the best update an android phone manufacturer has ever launched.
It is actually smooth and works almost flawlessly
If you are dying for battery put it on power saver 60hz mode.
BRILLIANT JOB SAMSUNG. LOVE THE UPDATE KEEP IT UP
cs_member8
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
