05-31-2025 11:57 PM in
06-01-2025 01:49 PM in
Galaxy SDear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
06-06-2025 08:51 AM in
Galaxy S- Mark as New
06-01-2025 02:18 PM in
Galaxy SLaughing for few minutes after seen your very funny reply whereas you mentioned to off all unnecessary apps, like wifi, Bluetooth, Hotspot, location etc. etc. I think it's better to keep the Samsung smartphone as switched off. No battery drain and no other issue even no green line issues. Dear Moderator, can you tell me if we keep the phone's all unnecessary apps off, why customer purchase your brand Samasung? And tell me why not under 10k smartphone? What deferent between Samsung and ordinary brand and between 1.5 Lac and 10K?
06-05-2025 07:14 AM in
