samjess
07-04-2025 09:13 AM in
I used my phone at night and left it when my battery was 47 % then I turned off wifi and removed the apps I was using then slept . Then when I woke up my battery was on 22% .
Why? And I keep my phone on power saving mode . Why is this happening. I even updated my phone . Please fix this.
4 Comments
Wodehouse
07-04-2025 09:37 AM in
Run device care. Also try these simple steps to save battery at the cost of sacrificing luxury
1 Enable Power saver
2 Enable performance mode light
3 Enable adaptive power saving instead of basic
4 Enable adaptive brightness
5 Disable AOD
6 Enable extra dim
7 Change display to natural
8 Screen time out to 30 secs (system default)
9 Record videos in FHD
10 Restrict gaming to HD or FHD and slower frame rate
11 Switch to dark mode
12 Disable near by device scanning
13 Disable WiFi scanning
14 If 5G is unavailable change network to LTE/3G/2G
15 Allow the battery to drain completely and recharge,say once a month.
16 Enable auto restart
17 Run device care
18 Disable apps running in background.
19 Disable RAMplus if you dont use memory intensive apps and do heavy multi tasking. Available RAM usually around 2 to 3 Gb is more than sufficient for normal tasks.
20 Uninstall bloat ware that came with your phone,eg. Spotify,LinkedIn etc.
21 Set display motion smoothness to standard.
You can mix match the steps above and arrive at a usage based on your needs.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
5 Disable AOD
6 Enable extra dim
17 Run device care
samjess
07-04-2025 10:25 AM in
I have tried many of these already nothing works as I mentioned my battery is draining so quickly even when my phone is not in use . I checked there are no apps that's consuming too much battery . My phone is in power saving mode . Still this is not good I have been a galaxy user for so many years im facing this problem for the first time ever . Disappointment is that I just bought my Samsung S23 only an year ago. I was so happy but this phone is giving me a tough time
goodthings
07-04-2025 01:44 PM in
goodthings
Your's most welcome to here.
