Battery drain issue in s23
(Topic created on: 06-30-2025 11:09 PM)
honey8088
Only getting 2hours 45 min sot in 5g 120hz refreshrate
And 3. Hours 20 min sot in 40 60hz
My phone is 2 years old, should I change the battery or this is update issue pls
Write your sot s23 users
SUDIP2003
Ha ha ha .
I am using S24 plus right now.
My suggestion don't go with s24 and s24 plus. Vivo is coming with most powerful OS ever (Origin OS). You can check that on youtube. It's just my suggestion.
honey8088
Yesh might be good compact handy phone ik in offline market i can easily get at 45k even after 3-4 month you will easily get it at 45k but still don't great at videos
SUDIP2003
Yes you are right.
honey8088
I didn't check it on only wifi I'll try it thanks for suggestions i will change the battery but I got little screen burn too💀 , so I don't want to spend more on this
Ujjal4928
This is mine i m getting decent battery backup nd note that i m not a gamer.1751306308655.jpg
honey8088
Which phone ?
Ujjal4928
Galaxy s23
honey8088
Maybe you've purchased few months back
Ujjal4928
Ive purchased after 3 months of launch not a big difference
honey8088
😢 same I've purchased 1 month old on 22 aug 2023 , I got screen burn too but it's barely visible in white wallpaper i don't want to spend more on this and change battery
