Battery calibration in s8 not yet fixed
(Topic created on: 03-27-2019 10:25 AM)
abisheknanjundan
I was a beta tester of pie, from the beginning there was a battery calibration problem , suddenly my battery percentage would drop from 30%to 5%.I thought it was software glitch which would be rectified in further updates but even after the stable update it has been not rectified, it's been really annoying.
  All i the only one facing this issue or else the whole beta testers..
3 Comments
MiraclePanda
factory reset once & try using the phone .
Bro i already tried once,no use ...
RumEro
there are other method on YouTube try it
