Battery Problem
(Topic created on: 03-16-2022 12:41 PM)
NitinSinghPathania
I have Samsung S20 Fe 5G. It's battery drain so quickly, not even able to surfing on my phone for 12 hours, I have to charge it atleast 3 times a day.
13 Comments
Ramamoorthy05
It's bad
Ramamoorthy05
Open < about phone < click more than 7 times then you receive developer option on settings then open < developer option then last end no background process and animation scale all are you manually set 0.5
sridharram
Beginner Level 3
Same problem 😕
Sid_Karna
Screen on time after full charge?
I have done all this, but battery drain more fast when I use it on wifi.
Sid_Karna
All what? I didn't suggest anything!!
Sáyân15
AYush2313
Same from this week
007Ansari
Bro you can fix Galaxy S20 FE/S21 FE Battery Draining Issue for this steps
1. Restrict apps that use the most battery
2. Remove or put unused apps to sleep
3. Turn off the features you don't need
4. Use the dark mode
Bro you can use this steps and save your bettry life
