Resolved! Solved
Battery Issue
(Topic created on: 10-01-2024 01:09 PM)
Destinier
I just bought a Samsung Galaxy S23 Ultra about three weeks ago, and I don't know why the phone's battery is draining too much without any reason.
Can anyone help me with this?
goodthings
Your's device is new so please give it some time. After some time and After some updates all is well. So please don't bothered about this issue now. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
17 Comments
Wait for some time brother sometimes it will analyse your usage then sot will increase when I bought s24 ultra starting few weeks it was like that if more than 2 weeks from now take to service center
Destinier
Okayy!
Thank you so much brother 🙏🏻
Welcome bro 😊
Shadman_Sinan
You can take these actions:
Firstly go to Settings---> Display--->
1. Turn on dark mode
2. Disable extra brightness
3. Set motion smoothness to standard
4. Set lower screen resolution.
I hope taking these actions will increase your battery life.
Please give feedback!
Destinier
Okay!
I'll definitely try these actions
Thank you 😊
Shadman_Sinan
You are welcome
goodthings
Destinier
Thanks for your solution 😊
goodthings
Your's most welcome.
