Battery Issue
(Topic created on: 12-06-2022 01:35 PM)
Ankisolanki
I am using S20 Plus Last Update Android 13 Samsung Ui 5 And My Phone Currently Working Android 13 Many Battery Issue In Hole Day 5th Time Charge Before Update In day 2 time Charge I am Not Happy With This Update Seriously i am Not Recommend Buy Samsung Device Seriously
3 Comments
After every update eventually phones get effected but obviously not all devices. Samsung must focus on bug-less update.
Ankisolanki
Yes But This Time Very Disappointed
cs_member8
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. And please follow the easy troubleshooting steps which might help to solve the issue.
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
