Battery Issue S25 Ultra
(Topic created on: 02-10-2026 04:55 PM)
Ebin_EVK
Team ,
Let me know does anyone having battery issue after below update .
Battery Backup is Declined Now .
What needs to do.
8 Comments
Here are the most effective steps to resolve battery drain on your S25 Ultra:
​1. Clear the System Cache Partition
​This is the most recommended fix after a major update. It removes old, temporary files that might be causing software conflicts without deleting your personal data.
​Turn off your device. ​Connect it to a computer via USB-C (this is required for modern Samsung devices to enter recovery mode). ​Press and hold Volume Up + Power until the Samsung logo appears. ​Use the volume buttons to navigate to "Wipe cache partition" and press the Power button to select. ​Confirm "Yes," then select "Reboot system now." ​2. Reset Battery Stats (Calibration)
​If the battery percentage seems to drop erratically, resetting the stats can help recalibrate the system.
​Open the Samsung Phone app (Dialer). ​Dial *#9900#. ​Scroll down and tap "BatteryStats Reset." ​Restart your phone.
​Note: You may need to disable "Auto Blocker" in Settings > Security and privacy to allow this dialer code to work.
​3. Check for App Incompatibility
​Apps often need their own updates to work efficiently with Android 16.
​Galaxy Store: Open the Galaxy Store > Menu > Updates > Update All. ​Google Play Store: Open Play Store > Tap Profile Icon > Manage apps & device > Updates available > Update All. ​Check Settings > Battery > View Details to see if a specific app is showing unusually high background usage. ​4. Wait for the "Learning" Phase
​Major updates reset the "Learning usage patterns" algorithm. It typically takes 3 to 7 days for the system to re-optimize itself based on your habits. During this time, the "Adaptive Battery" feature is retraining itself.
Ebin_EVK
Insightful. Will try these steps and will update here .
I'm using S25 ultra, I didn't face any battery issues
Ebin_EVK
After this specific update ?
Can you tell me the screen on time normally?
Everything was normal, this is security patch update. So nothing to worry. You can check your screen time. And try to check the screen resolution 1770735940162.jpg
Ebin_EVK
Noted Kartheeb.
Samsung_specialist
Thank you for reaching out. If your battery backup has declined after the update, please try the following steps:
  1. Check Battery Usage: Go to Settings > Battery and device care > Battery > Battery usage to identify apps that may be draining the battery.
  2. Update Apps: Ensure all apps are updated via the Google Play Store or Galaxy Store.
  3. Optimize Battery Settings: Turn on Power Saving Mode in Settings > Battery.
    Turn Off Unnecessary Features: Disable Bluetooth, Wi-Fi, and Location Services when not in use.
  4. Soft Reset: Hold Power + Volume Down for 10 seconds to restart the device.
If the issue continues, we recommend visiting a Samsung Service Center for further support:
Service Center Locator
Ebin_EVK
Noted.
