Battery Draining in s24
(Topic created on: 03-30-2025 02:50 AM)
BShu26
In S24, the battery is draining so fast. Even if I am not using it, it drained from 100% to 90% in just 5 minutes. Anyone else faced this issue? I tried checking the battery status and followed some quick fixes like Power saving mode and restricting background apps, but it's not helping.
6 Comments
msreja
Same problem on my galaxy S23
fzfalcon
Battery replacement needed
hpsingh75
Same problem in S23FE
goodthings
goodthings
Your's most welcome to here.
cs_member8
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
