Battery Drain
(Topic created on: 07-04-2025 04:48 PM)
Aamir_Butt
What is consuming battery? Major issue in One UI7 ever since i updated.
4 Comments
Samsung_specialist
we are sorry to hear that.
to help you more please try these steps :
1.Force restart by pressing “volume down key + power” button until the device reboot. After reboot below action.
2. Go toSettings – Apps - One UI Home – Storage - Clear data.
3.Settings > Software update > Download and install > Download > Install now.
4.Go to the Settings => select Device Care =>Optimize now.
Kindly make sure to follow these tips :
1. Use an Approved Charger.
2. Avoid Old Chargers.
3. Close Background Apps.
4. Enable Power Saving Mode (Device Care > Battery > Power Mode > Adaptive Power Saving).
5.Turn off the Wi-Fi, GPS, and Bluetooth functions when not in use.
6.In addition, reduce the screen brightness of your device.
If the issue persists after these steps, we recommend visiting a Samsung service center via this link :
https://www.samsung.com/ae/support/service-center/
Aamir_Butt
still facing the same issue
AK2016
My battery is draining during screen off time also, Internet off, WiFi off, Bluetooth off but still battery is draining too fast, I recently procured this mobile before 10 days back, and updated to UI 7.
Aamir_Butt
same issue with my phone...battery draining even when the screen is off...i guess there is some issue with One UI7
