07-22-2025 03:59 PM in
Galaxy S- Mark as New
07-23-2025 01:53 PM in
Galaxy SWhat's the solution of my new samsung S24fe fast battery drain ???
07-28-2025 08:15 AM in
Galaxy STo conserve battery power, your device offers several options, including optimizing performance through the device care feature, turning off the screen with the side button when not in use, enabling power-saving mode, closing unnecessary apps, disabling Bluetooth when not needed, turning off auto-sync for select apps, reducing backlight time, and decreasing screen brightness.
1
Check Task Manager and close unnecessary programs running in the background.
Galaxy S4: How to Reduce Device Heat and Battery Consumption?
2
Keeping Wi-Fi, Bluetooth, and GPS "ON" is often a main cause of battery drain and can lead to an increase in the temperature of your device due to searching for Access Points (Wi-Fi), Satellites (GPS), and other Bluetooth devices etc, Turn Off Wireless functions when not in use, You can use the quick panel menu to toggle Wi-Fi, Bluetooth and GPS on/off, or go into the device settings.
Tap the switch to turn off:
3
Turn off Tethering and Portable Hotspot function when not in use. This will increase the temperature and drain your device's battery.
Hotspot
4
Use only Samsung-approved battery, charger, and cable specifically designed for your device. Incompatible battery, charger, and cable can cause serious injuries or damage to your device
To save energy, unplug the charger when not in use. The charger does not have a power switch, so you must unplug the charger from the electric socket when not in use to avoid wasting power. The charger should remain close to the electric socket and be easily accessible while charging.
Using a power source other than the charger, such as a computer, may result in a slower charging speed because of a lower electric current.
The device can be used while it is charging, but it may take longer to fully charge the battery.
5
Some 3rd party applications which are downloaded from the Play Store may cause unwanted battery consumption and increase device temperature.
