Battery Drain
(Topic created on: 11-23-2024 01:10 PM)
wrathofgod2000
Hi, I’m using an S22, but I’ve been facing a battery issue recently. It’s draining way too fast. Is anyone else experiencing this? I always use my phone with power-saving mode turned on. Yesterday, I fully charged it, but within just 3.5 hours, the battery dropped to 25% while I was only watching YouTube videos.
11 Comments
ABL2021SGFan
Try booting the phone in Safe Mode. Or if the issue started almost immediately after you installed a new app, uninstall the app and look for alternatives.
Wodehouse
Battery drain issues can be frustrating. It's not uncommon for Samsung Galaxy S22 users to experience this problem, as seen in various forums and discussions.
To help you troubleshoot, let's go through some possible causes and solutions:
- *Check Battery Usage*: Review your battery usage to identify which apps are consuming the most power. Go to _Settings_ > _Device Care_ > _Battery_ > _Battery Usage_.
- *Close Background Apps*: Some apps might be running in the background and draining your battery. Regularly close unused apps or enable the "Put app to sleep" feature.
- *Adjust Screen Settings*: Reduce your screen brightness, turn off Always-on Display, or enable Adaptive Brightness to conserve battery life.
- *Disable Unused Features*: Turn off features like Bluetooth, GPS, and Wi-Fi when not in use to prevent unnecessary battery drain.
- *Update Software*: Ensure your device is running the latest software, as updates often include battery life improvements.
- *Factory Reset*: If none of the above steps resolve the issue, consider performing a factory reset.
If you've tried these steps and the issue persists, it may be worth visiting a Samsung authorized service center for further assistance.
Check the following links.
https://us.community.samsung.com/t5/Galaxy-S22/Alarming-battery-drain-on-S22/td-p/2803465
https://www.technobezz.com/how-to-fix-samsung-galaxy-galaxy-s22-battery-life-issues/
If this reply answered your query please mark my reply as "resolved" by clicking 3 vertical dots on top right of my reply. Thank you 😊
ABL2021SGFan
Hey, do you get these responses generated? Cuz I've seen this same pattern across every single comment of yours
Wodehouse
Similar or same problem evoke same or similar response
ABL2021SGFan
But these similar responses are also seen on unsimilar posts also.
I have already done everything except factory reset It happened like suddenly I think some kind of software issue that is why I posted this if someone is having same problem for past few days
Wodehouse
Factory reset often correct software glitches that happen during updates. You may try a factory reset. Please do backup
goodthings
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
