Battery Drain on S22 Ultra
(Topic created on: 10-22-2022 10:09 PM)
AshishKumar73
Huge battery drain happening on S22 Ultra after the October security patch. Maximum SOT of 3:30 Hrs.
8 Comments
Sid_Karna
Only 3.30 hr? You may use it as a land phone as well!
HritickDey
AshishKumar73
Wow. I have never reached 8 hours of SOT
Sid_Karna
Try playing videos for 5-6 hours and you may also get such sot.
I had same issue until yest that is how your phone adapts. But now Screenshot_20221023_124834_Device care.jpg
AshishKumar73
Thanks. Will observe it for a few days then.
I was in ur place until yest
cs_member8
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. And please follow the easy troubleshooting steps which might help to solve the issue.
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
