Battery Drain and Heating Issue On S21 FE SD 888
(Topic created on: 03-08-2024 01:19 AM)
mr_J_K_oley
Since a week I am being noticed that after the security patch of Feb 2024, battery of S21 FE is draining fast and it becomes warm rapidly (This is not usual). Previously this issue was fixed with One UI 6.0 android 14 update. But with feb 2024 security patch update it again came to s21 fe device.
 Requesting to the Team Samsung, please fix the issue and ensure that these kind previous issues which were already fixed, will not come with future software updates.
19 Comments
Ksamal
Yes bro...Previously i have also posted this issue....but no solution.....
mr_J_K_oley
If you're experiencing similar issues, or facing any other problems with your device, I encourage you to share your experiences online. By bringing these issues to light, we can put pressure on Samsung to address them and uphold their brand reputation.
Sayan2808
After July security patch update without any usage battery is getting drained by 50%.
Is anyone facing the same problem
pavanch
Beginner Level 4
Yes
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. Meanwhile turn off location when necessary open than close, stop all background apps also remove unused apps also put unused apps deep sleep or sleep mode, stop adaptive brightness, use 60 Hz.refresh rate of display, use dark mode. If you like please accept as a solution it's help to others users also, click 3dots in my reply section and click on accept solution. Thanks.
Ksamal
Yes bro u r right,but If I will do all these things then why should I spent 34k to buy this.I will go Other brands why I purchase this.....
mr_J_K_oley
If you're experiencing similar issues, or facing any other problems with your device, I encourage you to share your experiences in the community. By bringing these issues to light, we can put pressure on Samsung to address them and uphold their brand reputation.
Ksamal
Not me bro.. All s21fe 888 user are facing same issue and complaint through samsung member app... but developer have no reply and solution.Most of the thing FE series are highest demanded series of Samsung but they have lots of problems like Android version update and poor Optimization....
mr_J_K_oley
So we should raise our voice to reach upto Samsung and have to encourage others to post on the same issue..
Then only Samsung will fix it.
