Battery Drain after Android 10 Update.
(Topic created on: 02-01-2020 05:36 AM)
Akash17o7
Is anyone facing huge battery Drainage after Android 10 update/ One UI 2.0 ?
Smartphone Model - Galaxy S9
9 Comments
ROCKY316
Nope. I have a note 9 and it's perfectly fine.. I think you should get it checked at your nearest Samsung service center
Akash17o7
oh, Thanks a lot 😁
CaffeineCoder
yes I'm facing the issue with s9 plus
vkihba9
wipe cache partition and it'll be fine. mine is also s9
karrar
how i do that
vkihba9
switch off phone, then turn on by pressing power key, bixby key and volume up key together. release when android logo appears . then select wipe cache partition. don't wipe internal storage by mistake.
Akash17o7
Thanks a lot. 😁😁
karrar
thanks bro
Samsung_Support1
Hi there,
To resolve the issue please follow the troubleshooting steps provided in the given link: http://www.samsung.com/in/support/skp/faq/1101689
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > click on “+“icon > send feedback > error report/ask questions).
Regards,
Team Samsung Member
