05-07-2025 10:54 PM in
Galaxy S- Mark as New
05-07-2025 10:56 PM in
05-07-2025 10:58 PM in
Galaxy SOff screen time charge drain is drastic
I dont have any background apps running too 🙃
05-08-2025 10:39 AM in
05-08-2025 10:40 AM in
05-08-2025 12:48 PM in
Galaxy SDear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
