Battery Behaviour
(Topic created on: 07-16-2019 11:32 AM)
PGuddu
After getting the latest update phone battery is working unexpected. At point of 30% phone gets switched off under 5 minutes. Does anyone have this problem?
10 Comments
sret2910
which model do u have????
PGuddu
S8
ns46
try completely draining ur battery for 2-4 days charge it up to 80 -90% and see if it still happens as it might be caused due to over charging
sret2910
if again that problem happens go to service center and tell them software it with new updates and patches
Ahmed7391
yes I have this kind of problem
Goldychahal
*#0228# reset the battery with this code and then fully dischare the battery and charge to 100% in switch off mode.
PGuddu
no change, after doing this. what is best solution for this? @SamsungTeam.
Goldychahal
how old is your phone?
PGuddu
+2 years.
