Back Tap RegiStar Feature Drains Battery
(Topic created on: 10-16-2024 12:13 AM)
Tech_xplorer
I have noticed that Registar Good Lock module's back tap feature consumes battery more than expected. With module on I was getting around 6 to 6:30 hrs of SOT and now I am getting almost 8 hrs of SOT.
Device S23.
8 Comments
Devv_007
It uses some sensors, so.
Tech_xplorer
Yes, however, it should not drain this much battery. Iphone has this feature inbuilt and works fine
Devv_007
Iphones have very optimized software, and it's android ,so you can expect some battery drain.
Tech_xplorer
Well that's how OEMs give excuses 😁
PraveenKumarB
Keep in sleeping apps list and it will work only when you do any action
Tech_xplorer
Okay, will try that. You mean sleep list not deep sleep?
PraveenKumarB
Yeah..deep sleep will restrict entire functionality instead keep only sleep
Tech_xplorer
Makes sense. Will give it a try. Thank you!
