11-18-2024 03:42 PM in
Galaxy S- Mark as New
11-18-2024 04:17 PM in
11-19-2024 11:15 PM in
11-19-2024 11:19 PM (Last edited 11-19-2024 11:23 PM ) in
11-23-2024 02:34 PM in
Galaxy SDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open the Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select Error report > select the appropriate issue category> Type your query and send).
