Apps lagging in Ultra power saving mode S22+ Exynos
(Topic created on: 02-23-2023 03:15 PM)
shiron00
This is the setting where apps and homesceen are limited
Internet is slow to start up and WhatsApp chats are slow to open as well as Instagram chats. Keyboard is also slow to open and moving the cursor while typing too. It stops with a restart until I turn the ultra power saving mode again or change the apps that can be opened https://tutuappx.com/.
Anyone else noticed this? Been seeing this for the last few os updates but I have no idea how to fix it
2 Comments
cs_member8
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same and please follow the easy troubleshooting steps which might help to solve the issue.
Clearing the app cache is kind of like a cleanse for your apps. It will get rid of residual files that could be slowing down the app.
Open Settings, and then swipe to and tap Apps. Select or search for the app you want to clear. Tap Storage, and then tap Clear cache.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
store9
Your feedback at TellSchnucks.com will help the company improve and deliver the experience you deserve. http://tellschnucks.com.co/
