Anyone using Pitaka case for S24 series?
(Topic created on: 07-28-2024 08:29 AM)
NOMAĐ
S24 and Ultra cases
Pitaka cases are thin aramid fiber cases. I'm trying to find 1 in India but couldn't.
Anyone using the case on S Series??
14 Comments
Patil_0009
I use spigen case for my sam. Spigen is best in india just dont buy it from local shops . Buy it from vijay sales,samsung or any wellknown reputed store
sag120667
If you like silicone, try sprig silicone case. They are superb. Or you can also try daily objects. Real good drop protection.
NOMAĐ
Looking for a thinnest case. Checked daily objects but looks bulky
NOMAĐ
I'm looking for a thin case with magsafe magnets
Gadauli
I am using Ringke fusion magsafe case.
sag120667
I would recommend gadgetshieldz body protector instead. I have it on my s24 and they are really good. Ultra thin case is anyway not going to protect your phone, so by using those body protector, since they have scratch healing properties, you can use your phone naked without the worry of scratching your phone
sag120667
And plus you can use magsafe ring and stick it at the back so you have a protector plus with magsafe
Aiahwarya
Try goldenshield.com. They have collection of thin cases in which you can literally feel your phone. I'm currently using Aramid fiber case from goldenshield. These cases are protective as well.
You can find them on instagram.
NOMAĐ
Thanks for the suggestion.
I'm using Pitaka case now. Got it imported. Happy with the purchase. I'll try goldenshield when it wears out.
