Any solution to the network hanging / slow speed issue in the Samsung S20 FE 5G?
(Topic created on: 10-31-2022 04:34 PM)
sudhakar35gm
If you come across any solution, tell me.
23 Comments
Guddu-S20FE5G
Wipe cache partition
sudhakar35gm
I will try now. Apps and personal data in the phone memory won't get erased. Right?.
Yes it doesn't affect your data
Guddu-S20FE5G
Yes
sudhakar35gm
Hey. How to do that without connecting to PC?
I think it is not possible to do that without connecting to the PC
Ya i also think so.
sudhakar35gm
Ok
sudhakar35gm
Any way to do without connecting to the PC?.
Can you factory reset your device?
Kyuki ab mere pass koi solution nahi hai bhai.
Solutions that i know
1. Reset network setting
2. Clear cache partition
3. Reset APN and set DNS to automatic
4. Insert you SIM Card in slot 1, enable data roming and select 2g/3g/4g auto
5. Turn off data saver and battery saver
6. See attached file(photo), set data limit to as maximum
7. Factory reset (last solution)
Note:- after doing step 3 or 4 just restart your device.
