SatC
02-10-2018 03:33 PM (Last edited 03-16-2019 05:12 PM ) in
@ Samsung, What's the consequence if I switch off "Allow background activity" for Android System. Notice that it's using up more battery.
What will stop working or will have an impact if I switch that OFF.
4 Comments
roshini96
02-10-2018 03:36 PM in
open this👉 http://bit.do/samsung-app-link-download
AbhijithSB
02-10-2018 03:45 PM in
Well, try turning it off and find out for yourself. How bad can it be?
ujjwal201
02-10-2018 04:39 PM in
It doesn't work. You need to stop Google backup and clear Google play services data.
admin_
02-12-2018 02:04 PM in
Thanks for reaching out to the Samsung support communities! We would like to inform you that Android system is an essential application and need to be active in the background to run the device smoothly. Disabling the option "Allow background activity" will result in device instability.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
