ashwaneee
04-20-2023 06:33 PM (Last edited 04-20-2023 06:35 PM ) in
Galaxy SHello Friends I'm seeing that most of us are facing Low Battery and Heating issues on our phone. So here I'm sharing my experience with you all by which I'm getting around 4.5 - 5 Hrs of SOT on My Galaxy S22 and noticeably low heating.
2. Regularly clear recent apps.
3. Put unused or rarely used apps to deepsleep.
4. Browse Facebook and Instagram from the browser itself, as both of these apps consume alot of battery and data.
5. Start using data saver as it cuts down on background data syncing activity. You can only allow some of the necessary apps to use data like whatsapp, email and truecaller.
6. Stop using always on display as most of us always keep are phone in our pocket or in hand, so no sense of using AOD.
7. Use dark black wallpaper as well as dark mode on your phone.
8. Also I have noticed that whenever I put my phone on 5G, my phone starts heating and Ram usage also increases. Network also fluctuates between 4G and 5G, that affects battery.
9. When you're in low network area, avoid using data connection as mobile consumes more battery searching for network.
10. Charge your phone from 15% to 85% in one shot, so that battery can adjust itself according to your usage patterns.
11. Use only Samsung's original adopter and cable to charge your phone.
12. If you regularly watch movies or videos on your phone, use a mobile stand for it as sometime device gets hot due to our body temperature.
13. Install only important apps which you use on daily basis.
14. Also you can disable some of the built-in apps from Google and Samsung.
15. If you're not a heavy user then don't use back cover on your phone as it restricts phone from releasing heat.
16. You can customise your phone by using good quality skin wraps, they also prevent your phone from getting daily routine scratches.
17. Don't use your phone while charging.
18. Stop all the annoying notifications.
19. Switch off GPS, Bluetooth and Mobile data when not in use.
20. Use adaptive brightness feature.
Friends the points which I have shared above are according to my usage patterns.
Other user's reviews are also welcome.
All in all Galaxy S22 is a very powerful device, I know there are some problems but considering it's size and beauty, we should avoid that.
#Samsung #Galaxy #S22 #Battery #Heating
#Tips
10 Comments
- « Previous
- 1
- 2
- Next »
ashwaneee
11-04-2023 11:11 AM in
That was for S22 base model, not plus varient
- « Previous
- 1
- 2
- Next »
