3.5mm Audio jack / Adaptor for S21 Ultra
(Topic created on: 04-25-2021 07:05 PM)
Anak1n
Can any one suggest USB type c to 3.55 audio jack or adaptor?
Also, I am looking for adaptor which supports High quality DAC/audio with mic and remote button supports.
Please don't suggest any random link, would be great if you can share one you own or the one you trust.
THANKS !!
11 Comments
Jassimsheik28
U can use Bluetooth headphones instead of 3.5 mm jack
Anak1n
I got pretty expensive earphones, that would be wasted if I opted for Bluetooth. That's the reason I am looking for adaptor.
Jassimsheik28
Ok bro then in flipkart it is there at 240 excellent product
Ravi0883
Also you can buy samsung adopter
Anak1n
Well some are saying in samsung ommunity and in YouTube comments, it doesn't work in S21..
Also, I shortlisted below one, but few reviews said, it doesn't work in S21 . I AM TOTALLY CONFUSED NOW...
https://www.amazon.in/dp/B08GFJRRQ9/ref=cm_sw_r_cp_apa_glt_fabc_RFT5M3X3R0G6TQYJY5JJ
THIS ONE IS THE KIND I am looking for, a HiFI audio quality DAC support..
Ravi0883
Go to Samsung Cafe and check yourself. If it will work or not. In my opinion it should work.
Anak1n
Thanks for your suggestion, will see about that. 😃
Ravi0883
If it works then tell me I am also in search of good adopter.
TimonN
Expert Level 4
This happens when basic features are removed.
Users are forced to spend more, no guarantee of whether such adapters will work, also not good for environment.
