location problem in on5pro
(Topic created on: 01-15-2018 09:47 PM)
chai123
Galaxy On
Map shows wrong location in on5 pro.Plz do something to resolve this problem.
3 Comments
s01gautam
Galaxy On
https://play.google.com/store/apps/details?id=com.application.onead&hl=en Your friend has invited you to try OneAD app. OneAD is Refer and Earn + Shop and Save mobile app. Install this free app become a member and earn up to 2.5 Lakh Rs per month. Your referral code for registration is reffer code -"M1EQFP"
Manzer
Galaxy On
https://play.google.com/store/apps/details?id=com.application.onead&hl=en Your friend MohdFahad Manzer has invited you to try OneAD app. OneAD is Refer and Earn + Shop and Save mobile app. Install this free app become a member and earn up to 2.5 Lakh Rs per month. Your referral code for registration is SBNZEN
admin_
Galaxy On
Thank you for being with Samsung and sharing your concern. We would like to offer some troubleshooting steps to overcome the issue:
1) Navigate to Settings >> Apps >> Select Google related Applications >> Clear Data & Clear Cache.
2) Navigate to Settings >> Apps >> Press on More >> Reset App Preferences.
3) Update the device or application if available.
Be sure to hit ♡ when you find an answer that works for you.
