rambala007
04-07-2018 07:47 PM in
Galaxy On
just bought Samsung galaxy on 7 prime. turned on LED indicator in settings. correct me if am wrong in my understanding, I thought during charging, the LED should glow in red colour till it reaches 100%. then it should turn to green, though power cord is connected. once we unplug it, it should blink in blue colour. but nothing is happening as such. i did diagnostic testing on sensors, all are fine.
7 Comments
macsingh
04-07-2018 08:04 PM in
Galaxy On
i think samsung should give a setting of customization to led indicator as it doesn't shows the proper led notification!!!
AbhijithSB
04-07-2018 08:16 PM in
Galaxy On
LED indicator wouldn't blink Blue (or any colour) unless there is any notification. And certain notifications will prevent it from glowing red while charging.
rambala007
04-07-2018 08:28 PM in
Galaxy On
oh,I checked and enabled all possible things to make LED indicator to blink. even restarted and given missed call from my brother's mobile, not blinking still
Selvam
04-08-2018 12:30 AM in
Galaxy On
Do a factory reset and try it
thelegend
04-08-2018 04:34 PM in
Galaxy On
u can call *#0*# to check if the led is working or not
rambala007
04-08-2018 05:08 PM in
Galaxy On
yeah, I did it. given a diagnostic run to check sensors. the run seems to be a never ending one. don't know how to stop that. so restarted the mobile.
admin_
04-09-2018 10:48 AM in
Galaxy On
Thank you for sharing your concern. The relevant department will serve you better/speedily, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
