[How-To] Reinstall firmware using Smart Switch (Samsung Galaxy On Nxt)
(Topic created on: 09-20-2017 07:08 PM)
ParasVerma
Galaxy On
Hey there,
I was recently experiencing some errors in the software of the device so I decided to reinstall the firmware officially using Samsung's Smart Switch.
It asked for Model No. (entered : SM-G610F), after that it asked for S/N (entered the no. printed on the back labelled as 'S/N').
But, after entering S/N it showed an error (check the Model No. & S/N).
I don't want to use Odin as it adds up to the flash counter (some other issues too).
Please help me to reinstall the firmware OFFICIALLY.
♡THANKS IN ADVANCE♡
6 Comments
Not applicable
Galaxy On
the firmware will come after some time on smart switch have patience
ParasVerma
Galaxy On
How much time it usually takes?
Not applicable
Galaxy On
2-5 days max
ParasVerma
Galaxy On
Are you sure?
And thanks for the information.
Not applicable
Galaxy On
j7 prime's rom came after 5 days of update release
admin_
Galaxy On
Thanks for being with Samsung and for sharing your concern. Kindly check given below procedure for updating device through Samsung Smart Switch at Home.
Requirements:-
• High speed internet connection (minimum 2 MBPS)
• Handset’s battery should be fully charged.
• Continuous Power backup (in case of power failure, handset might be crashed)
Step 1
Install the updated version of Samsung Smart Switch in your PC/Laptop. The same can be downloaded from the link given below-
http://www.samsung.com/in/support/smartswitch/
Step 2
After installation of smart switch on PC/Laptop, connect your handset via USB cable with PC/Laptop.
Step 3
Notification will appear in Samsung smart switch window if the updates are available for respective devices.
Points to remember:-
1. Do not disconnect the handset during firmware updation.
2. Please ensure that power supply and internet connection don’t get interrupted.
3. This process might take 30 – 45 minutes approximately depending upon the internet speed.
