regarding note 8 battery issue
(Topic created on: 10-21-2018 12:50 PM)
erank
Galaxy Note
Hey anyone tell about note 8 battery life???? Last night I have used my phone and battery shows 42 % and in the morning when I charged my phone its battery dead and switched off the phone
7 Comments
Galaxy Note
I suggest you to
1. update your device from setting >software update if avalable.
2. use your device in safe mode for some time if you are facing some issue
Safe Mode allows the device to boot up without  installed third party apps running, which will conserve battery power.
To start the device in Safe Mode, with the device Powered Off.
① Press and hold Power key.
② Once the animation starts, Press and hold the Volume down key until the lock screen appears.
③ Keep the Volume down button until device boots up.
④ Safe Mode is indicated in the lower left hand side when enabled.
⑤ To get out of Safe Mode restart the device.
if your problem is not solve you can ask again
 you can also call Samsung Customer Care Number 1800-40-726-7864
if you find my answer useful please hit the ❤ option. and follow me
i am happy to help you
Galaxy Note
change the battery
Shiv9564
Galaxy Note
Charge your battery from 0 to 100%. Restart your phone if problem continues go to service centre.
Vihaan9845
Galaxy Note
Reconfigure battery calibration
AyushRaj
Galaxy Note
I suggest you to update your phone from samsung authorised service centre
YRSS
Galaxy Note
Delete some app for some days and see any improvement is there as some apps consume too much battery. If still have same then change battery.
sarinbp
Galaxy Note
may be some apps or background sync cause this issue. my note8 also has this issue one night. don't worry
