note8 beeta ONE UI update kare ya na kare plz hlp
(Topic created on: 01-20-2019 12:26 PM)
Sureshkp
Galaxy Note
Note 8 me beta software update Kare Ya Na Kare final update isme ho jayega any idea please comment this
9 Comments
iamsahilsetia
Galaxy Note
krlo
NaveenGohar
Galaxy Note
nahi
Sureshkp
Galaxy Note
kyo
NaveenGohar
Galaxy Note
you will suffer with Screen resolution like I'm suffering
NaveenGohar
Galaxy Note
also with battery drain
NaveenGohar
Galaxy Note
Hi guys since I have update from android oreo 8.1.0 to pie 9.0, I feel the Screen resolution or screen size is got smaller then oreo also my battery is getting drain very fast. I like the bigger screen task like navigation/ gesture bar which was pretty awesome in oreo that we can pull up from down whenever we need to use the navigation bar. In pie it stays permanently, which is effecting the look by occupying the space
Also I noticed that whenever I'm watching the pictures from gallery or any videos even from YouTube it's shows in small screen in horizontal position both left and right sides screen shows the place which is black, before it was shown to the fullest Screen like upto all 4 sides till edges
Pie is good for small Screen mobiles not suitable for galaxy note 9 bigger screen
Its just my point of view, I'm not sure about others thinking.
Regards
theKeshavKr
Expert Level 4
Galaxy Note
I would suggest you to wait for the final update.
Galaxy Note
even the final update is shit. so please don't update. Beta updates you should never try. They are basically launched for testing. and usually there are lots of problems in them. so its better to get the full stable version
vinayshah
Galaxy Note
After going through many posts and feedback here on this forum, I'm not updating my phone to beta.
