note 20 ultra package installer problem
(Topic created on: 11-27-2020 10:03 PM)
shreyac12
Galaxy Note
After updating to  anroid 11 beta 3 my package installer keep stopping nd i also tried force stop ,clear data but it is still not working
5 Comments
sumantyadav5321
Galaxy Note
1.try to reset settings only.
2.if not works send error report to Samsung using this app.
shreyac12
Galaxy Note
ok i will try
Not applicable
Galaxy Note
cs-member13
Expert Level 4
Galaxy Note
Dear Samsung Member,
We are sorry for the inconvenience caused to you. We request you to kindly send us the error log file again along with the Video or Screen-shots within 15 minutes of issue occurrence through error report section from Samsung Member Application:- Samsung member > Click on beta banner > Switch to beta mode > Beta feedback > Send feedback > Error report. As this will help us to further investigate and resolve your concern.
skyler1206
Galaxy Note
it is started on my device s20 plus also. reported logs.
