note 10 plus battery drain
(Topic created on: 11-01-2019 06:59 PM)
notefam
Galaxy Note
Its been five days since i have been using my note 10 plus....i noticed a very steep battery drain...i had xs max which i switched with my brother for my S8 b4 i bought note 10 plus... the battery on max felt a bit stronger....but when i put the usage side by side...running same apps...i noticed that from 100 to 90 % the drain is very higher for galaxy ...but the drain in iphone is merely 95%...
Then comes the plot twist , from 90 to 60... note took over soo much that xs max was left at 55...
Soo unsymetrical battery drain in iphones...that actual made me think" did i just sweep an unlucky note 10 plus?"
Its a good battery life....put screen to max resol. But the cpu limit to 70% thru medium power saving is more effective....i love this screen...
Just my experience , plz reply ur battery saving tips
2 Comments
batking33
Galaxy Note
100% to 90% is totally normal, its actually increasing your battery life over the years
https://phandroid.com/2010/12/25/your-smartphones-battery-gauge-is-lying-to-you-and-its-not-such-a-b...
Samsung_Support6
Galaxy Note
Hi there,
To resolve the issue please follow the troubleshooting steps provided in the given link: http://www.samsung.com/in/support/skp/faq/1101689
We can guide you further if the issue persists after performing the specified steps.
Regards,
Team Samsung Members
