Resolved! Solved
note 10+ camera edge light
(Topic created on: 04-14-2020 10:01 PM)
more0804
Galaxy Note
How to enable camera edge light...
3 Solutions
Galaxy Note
Bro, download edge lighting+(Samsung official app)..after that
settings>display>edge screen>edge lighting>lightning effect>select black hole effect
http://apps.samsung.com/appquery/appDetail.as?appId=com.samsung.android.edgelightingeffectunit
Galaxy Note
Bro, if problem solved then click at 3 dots near my above comment and accept it as solution to help others 👍🙂
Galaxy Note
No, bro...you can try some themes or wallpapers from galaxy store
10 Comments
Galaxy Note
more0804
Galaxy Note
thanks brother 😊
more0804
Galaxy Note
thanks bro..😊
more0804
Galaxy Note
thanks bro..😊
Galaxy Note
more0804
Galaxy Note
is their any app or settings for change finger scanning animation
Galaxy Note
more0804
Galaxy Note
can u just for example
Galaxy Note
