improve battery on note10plus
(Topic created on: 11-16-2019 11:06 PM)
sarfarazahmed
Galaxy Note
What to do to improve my battery
2 Comments
GHOST007
Galaxy Note
make sure the background apps are closed except only important apps.
reduce the resolution to fhd+ while not watching videos.
make sure bluetooth, nfc,auto sync is off.
Gst26
Galaxy Note
As per this Screenshot..Screen & YouTube are Consuming almost 1/4 of your Battery... First use Power mode on Optimised mode, Second Check display Settings like Brightness, Screen Resolution etc. apply Adaptive Brightness, Night mode.. Third put apps in sleep mode in device care immediately after no use and Restricts Background battery usage in App info.. Don't apply this on system files..
