fast charging problem
(Topic created on: 09-28-2020 11:35 PM)
Not applicable
Galaxy Note
6 Comments
Ehsank
Galaxy Note
did you check with other cable?
Not applicable
Galaxy Note
hm but not fast change
apratim2
Galaxy Note
have you turned off fast charging under battery settings?
DrOmisha
Galaxy Note
check charging settings : settings > device care > battery > charging > fast charging.
see if the toggle is on or turned off.
Not applicable
Galaxy Note
fast charging on battery settings, but not fast charging
Dilli
Galaxy Note
When battery heats up while fast charging it switches to normal mode as safety measure. Next time try fast charging in cool environment.
