battery problem drain
(Topic created on: 02-21-2019 09:38 PM)
aayan
Galaxy Note
When i get new ui in note 8 . it works good but i facing a problem   in battery drain plz  help
6 Comments
rony7659
Galaxy Note
plz tell me how can i get pie update on my note 8
Galaxy Note
Samsung will realeasd it .
aayan
Galaxy Note
go to the settings and chk software update and click on download manually
Galaxy Note
Install Smart Switch app on your laptop and connect your phone you'll see the update
aayan
Galaxy Note
what about battery darin
admin_
Galaxy Note
Thank you for sharing your concern. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members BETA App ->BETA Feedback > Send Feedback > Error reports > collect log file > Attach). Be sure to hit ♡ when you find an answer that works for you.
