Resolved! Solved
battery drain problem
(Topic created on: 04-27-2020 10:47 PM)
Nirmal1008
Galaxy Note
I found my note 10  lite battery draining fast ..From last full charge ,I saw some applications are using much battery.
Apps are:-
#Find my Mobole
#Voice wake up
#Digital Wellbeing and parental controls
Can some one help to to unstall these apps or how to stop them to work automatically to save battery power
I am really disappointed with the battery of note 10 lite .
Thanks you
2 Solutions
S_Kumar73
Galaxy Note
Actually I turned off location( including wifi and Bluetooth scanning), NFC, Bluetooth, dolby atmos, disabled Facebook, few Google apps like moves, music.., turned off auto brightness and kept the brightness at 40%. turned off wifi auto connect, turned on wifi power saving, turned on adaptive battery kept the mode in optimized turned off AOD. I killed all the background apps, I turned off notifications for all the 3rd party apps except whatsapp, also turned of auto sync, I even turned off advance features like double tap to wakeup, lift to wake up etc.. also keep the screen in FHD. only thing on is the phone
but still the 6 ½ hours it drains 7% in standby. Samsung really collapse the battery optimization in one ui 2.1. very very pathetic situation. I used few LG flagship phones, in that the standby time is excellent, in the ssme 6½ hours it discharge only 1.5 % to 2 at the max. better samsung can get some expert idea from LG how to do that.
SAMSUNG CAN YOU PLS HIRE SOME EXPERT WHO REALLY KNOWS HOW TO OPTIMIZE THE BATTERY,
MaverickSiD
Galaxy Note
After updating my note 10 plus to UI 2.1, Super fast charging is not been displayed on screen or screen lock while charging the phone with OEM charger and usb and also cannot find super fast charging toggle in battery settings, only fast charging toggle and fast wireless charging option is available while the super fast charging option has vanished! is it just me or there are others too who are facing these same issues? Also facing horrible battery drains and it is taking 15 minutes more to fast charge from 0 to 100% as compared to charging prior the UI 2.1 update! any solutions
available? Hoping to get an early revert. Regards.
4 Comments
arunnechlani
Galaxy Note
You can follow below steps to save your battery life.
https://r2.community.samsung.com/t5/Tech-Talk/Battery-saving-tips/td-p/2920797
S_Kumar73
Galaxy Note
Dilli
Galaxy Note
The exynos Chipset is to be blamed. put all above apps to sleep in background.
MaverickSiD
Galaxy Note
