USB connected/disconnected problem
(Topic created on: 02-05-2021 08:26 AM)
AllezAllezAllez
Beginner Level 3
Galaxy Note
My Note10 Lite keeps notifying me USB connector connecting/disconnecting. Does not charge all the time as well.
5 Comments
Maps_sam07
Galaxy Note
Hi, AllezAllezAllez please perform a soft reset of your device.
Press and hold the power and volume down buttons for about 10 seconds.
*The device may take a screenshot, however, keep holding the buttons for a few more seconds. This is a soft reset and will not factory reset your phone.
MermaidZA
Beginner Level 3
Galaxy Note
Thank you. My issue has been resolved.
Alij2021
Galaxy Note
Has it solved your issue?
mohlwethu
Galaxy Note
Mine to has the same problem
Channa297
Galaxy Note
Have you found the problem ?
