Samsung Galaxy Note 20 ultra call recording not enabled
(Topic created on: 11-18-2021 11:01 PM)
imKTR
Galaxy Note
Hello, i cannot use/get the call recording options here im my Galaxy Note 20 ultra. Its from UAE. I need to use actually.. what should i do even if i need to change the region or something else to enable/get this call recording options in my phone app. Thanks in advance ☺️
3 Comments
Galaxy Note
CONTACT WITH SAMSUNG CARE
THEY WILL ANSWER YOUR QUESTIONS ABOUT THIS
saarang007
Galaxy Note
Some features are not available depending on the regions. I think U.A.E. is in that list (no call recording). Laws in U.A.E. do not allow it.
You can either manually flash Indian unit ROM (which is a bit risky) or use some 3rd party app (relatively safe option).
https://www.slashdigit.com/how-to-enable-automatic-call-recording-on-galaxy-note-20/
You can try turning off VoWi-Fi but I don't think it will help.
Install a call recording app from the Play Store after reading reviews.SmartSelect_20211119-182256_Samsung Internet_47870_1637326376.jpg
imKTR
Galaxy Note
Thanks for your kind suggestions
