Samsung Galaxy Note 20 Ultra Mobile Network Problem
(Topic created on: 11-22-2024 06:30 AM)
Millz1
Galaxy Note
My galaxy note 20 Ultra has lost moble network. I have tried to insert a different simcard but to no avail. I have also tried to factory reset it but still no mobile network.
As you can see,flight mode is auto enabled and it wont turn off. How can I fix this problem?
17 Comments
Galaxy Note
Try Disabling Airplane Mode via Safe Mode
Turn off your phone. Press and hold the Power button until the Samsung logo appears, then release it.Immediately press and hold the Volume Down button until the home screen appears."Safe Mode" will display in the bottom-left corner. Check if you can disable Airplane Mode in Settings > Connections.
Millz1
Galaxy Note
Even from safe mode ,flight mode could not be disabled
Galaxy Note
I came across with a person with the same problem,but I can't recall the exact solution that worked when helping him
Millz1
Galaxy Note
Please try to remember. It will really be helpful
Galaxy Note
I will try to remember
Millz1
Galaxy Note
Thank you. Let me try that. I'll update you wether it works or not
Galaxy Note
Or try updating your phone to it's latest software update, or dial *#06# and check your IMEI if it's shows null or unknown, your phone's network firmware might be corrupted
Millz1
Galaxy Note
Unfortunately, note 20 series were discontinued meaning no official updates or support from samsung. Unless I try to root it and update manually 1732303771446.jpg
Galaxy Note
Or try resetting network settings
